1. Place temperature lever to max hot setting. Disconnect temperature control cable from blend air-door lever.
2. Pull heater valve control rod in direction to obtain .08" (2.0mm) clearance between ends of rod and link lever. Connect Rod to door lever. Check operation of air mix door.
3. Push temp control cable and air mix door lever in direction of arrow. Install Retaining clip.
My question is, where is this located, and if the heater control valve is sticking, this is what will fix it? Thanks
