Adjusting Headlights Left and Right
Bmore2ny
Car: 06 Infiniti M35x
I have an 06 M35 and my right headlight is aimed to the right about 45 degrees. Any suggestions how to fix this? I've searched the forum and was only able to find post about adjusting up or down.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Not putting much thought to this answer but my first guess is your AFS (adaptive headlights) may have gone out!! At start up our lights self level up and I know there are adjustments that can be made for up and down... Just my 2¢ :gotme
sergio1987
Car: 2006 Infiniti M35X
I think you are right the AFS might be bust or just stuck... Try disconnecting the battery for 15 minutes(or better overnight) and see if that will help. Does your AFS light come on on the dashboard?
Bmore2ny
No AFS light. If it is out can they be manually adjusted when I go in to change the bulb?
The Bodyguard
Bmore2ny wrote:No AFS light. If it is out can they be manually adjusted when I go in to change the bulb?
Not sure but worth a try!! These headlights are expensive ($1200) I had one replaced under warranty due to the AFS motor going out!!
Bmore2ny
I guess I can't make it much worse.
Wangtang408
there's a post and video created by a member name JoshTex, hope that helps you
headlight-adjustment-i-figured-it-out-t ... =headlight adjustment
