Adjusting head lights on 07 sentra
bakerboard
Car: 2007 Nissan Sentra S 2.0
So i recently got HIDs and i thought they were fine. Last night i was behind someone and i realized they may be a little to high because i could see the lights in the rear-view mirror. My question, Is there a way to adjust the head lights so the light points down more?
Hopefully im being clear about it! If im not just ask.
Faja
Car: 2009 Nissan Sentra
Yes,
Modified by Faja at 8:57 PM 10/4/2009
bakerboard
Sweet! ok the only thing is i cant read it haha. Is there a link you can post? or is it in the owner's manual?
Faja
It's in the FSM. It's just an adjusting screw that you turn. It's located in the slightly dark spot to the bottom right of the picture (has a B pointing to it if you can make it out) - will try to make the picture bigger.
Modified by Faja at 9:14 PM 10/4/2009
bakerboard
Ok so i adjusted the passenger side down about 6 inches and i went to the driver side and the screw/nut thing came out. i had cracked what was holding it in place and so i cant lower the driver side anymore... idk what to do. I got the driver side down about 2 inches and since it was fcked up i had to move the passenger side back up so it was level. I hope those 2-3 inches will stop people flashing me haha!! or else ill prolly have to get new headlights...
Faja
Yeah, I was kinda worried about the glare from the very start. If you stand about 35-40 feet in front of the car you'll should be able to tell if the glare is still there which I suspect will be so. I believe some people have built some custom-made bulb shields that have helped by eliminating the bottom side of the reflector housing - not perfect but it does help.
bakerboard
Ill try that out. I only get flashed by small cars that sit lower than me. Trucks and everyone else i dont get flashed.
ABNRML4U
Car: Nissan B13
Man, Just take your time what is your hurry on ajusting your head lights. GL on fixing your lights. What is the latest news on your new wheels that your going to get?
bakerboard
haha i did not hurry at all. I take time to do stuff on my car so i dont mess it up. I think it was just a cheap piece.
