Adjusting Coilovers
Ceptos
Car: 95 240sx
Been thinking about this lately, is there any popular or standard method to adjusting coilovers? should i start at the hardest setting and count down, or start at the softest setting and count up? thanks for any opinions
SmithSR
Car: 240sx
I start stiff and work down. At the point where coilovers are used, ride quality is shot, but trying to dial in some amount of suspension travel while keeping the rigid handling will be key. Most of the time people that come in to the shop say they set to the softest because any other setting is intolerable. I often wonder if they can really tell any difference..
Ceptos
Car: 95 240sx
yeah, im more concerned with getting them all to be even than i am the overall stiffness. its seems hard for me to tell exactly where each one starts and stops and i want to make sure im starting at the same point for each of them. thanks for the help, ive been doing the opposite of you, but ive heard thats popular so ill readjust them soon.
Dori Dori
Car: Cars of course
You should check the manual or contact Jic. IIRC for KYB's, they tell you to go back to the lowest setting counter clockwise and then adjust clockwise to the setting you want.
eddiec
Car: 91 S13
are you just adjusting the dampning or the ride height? for myself on the dampning i started full soft and counted how many turns i turned the knob. turn the fronts and rears the same amount. now test drive. repeat until out of adjustment range or its the way you like it.
aleph1
Car: 1990 240SX hatch MODS: class.
Corner-weighing?
Ceptos
Car: 95 240sx
jic told me to start at full stiff and count down for dampening.
