adjusting coilovers.......no experience
Zak427
Car: 93 2+2 Twin Turbo
I justed ordered some spl kts coilovers for my Zi've never worked with coilovers before. so setting the proper shock travel and spring preload is greek to me...can someone walk me through it. if i can get them to stock settings. i could use it as a baseline. i'll find out tomorrow if they come preset or not. yes the web site has a good gouge on how to set it. but where to start?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
what will the car be used for? what are the spring rates?the basic set up is to load the spring enough that you don't get any spring hop at full extension, then the car needs to be put on conner scales with the driver in the seat and adjusted for drossweights, spring rates can be changed to ashieve the desired handling characteristcs, the pearch is to adjust the preload and fine tune the crossweights
Zak427
8kg/mm front 6kg/mm rear
for street use
WidebodyZ
Car: X300 LWB Vanden Plas / W203 C240 Luxury Sedan
Honestly there is no "best setting" for everyone. In fact, I encourage you to test settings out and see what works/feels best to you. I personally run 13/11 spring rates and lay my car on the ground and yes, daily'd that way. Clears the tallest speedbump where I live..well, scrapes over it is more like it, but still.
