Adjusting Coilover Camber
240sxHitman
Car: Boosted '91 240sx
I was just curious when adjusting the camber plates do you do it while the car is in the air or can u do it with the car on the ground?
Exar-Kun
Car: 2005 350Z
on the ground....if it's in the air the tires will lean in and such, reuining your measuring ability..unelss you want to lift, adjust, measure, repeat like 6 times...-chet
