Crazyirish wrote:Also a lot of shops just set your toe and dont bother with caster/camber settings unless they are seriously out of spec.
Usually what gets aligned depends on the factory adjustments. I've spent an hour on toyota seqouia and 4runners with fully adjustable front ends, all of which is factory. That **** is seriously annoying and time consuming.
As far as a difference from side to side caster, having a stagger won't make a huge difference unless its in excess of 1.5 degrees. Nascar teams run a heavy caster stagger so that the car naturally wants to turn in and the driver fatigues less due to the ease turn in. If you're a drifter, increasing negative caster will speed up the steering wheel's return to center, making it easier to toss the wheel from lock to lock.
....I love suspension babble.
