adjusting caster + toe on y33 q45
Qproject
can you adjust caster and toe with stock suspension parts ?
Q45tech
THe only front thing that can be adjusted on 90-2001 Q is the TOE without aftermarket parts or bending/shimming.
Qproject
is caster adjustability important for lowered cars?
Im trying to decide if I should get adjustable tension rods or just swap out the tension rod bushings.
thinking about this:
http://cgi.ebay.com/ebaymotors...ZWDVW
Qproject
Q45tech
Caster equality side to side is extremely important otherwise there will be a side to side drift.
As with camber the caster should be within a few tenths of a degree side to side.
Qproject
I thought TOE was more important no ?
Q45tech wrote:Caster equality side to side is extremely important otherwise there will be a side to side drift.
Qproject
and which suspension parts are use to adjust TOE ?
I have coilover camber plates for camber, I know tension rods adjust the caster but what about toe ? what part is adjusted to adjust toe ?
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Toe-tie rods
