Adjustable Upper Control Arms Necessary?
robertrio
Car: 1991 300ZX NA
Is it necessary to get adjustable upper control arms if I switch to, say, the Tein Flex Z Coilovers? I just replaced my upper control arms with OEM replacements.
NolimitZ32
Depends on how low you plan to go and if you really care about proper camber.
robertrio
Car: 1991 300ZX NA
ONly looking to lower about an inch. Looking more for ride comfort.
NolimitZ32
Unless you'll be adjusting your ride height you're likely better off with some good quality progressive rate springs and struts designed for whatever drop the springs provide.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
robertrio wrote:
Fri Jun 12, 2020 4:53 am
For a 1" drop, 300 degree camber plates will bring your camber back to OE specs. Low cost and effective.
PM sent.
