adjustable rear upper control arm install
93Z
Car: 1993 300zx 2+2
I think I can handle the install it doesn't seem to bad but once I get them installed can I adjust the camber then get everything aligned or does a shop neef to do everything?
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Make them the same length as stock and have alignment shop fine tune it.
93Z
Car: 1993 300zx 2+2
After all that do I need a 4 wheel alignment. Or if my alignment is recent is it all okay
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
I would at least, go get it checked. Generally, you should always do an alignment if your are replacing suspension parts.
