Adjustable Fpr
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Hey, I recently went to take my 240sx into a dyno.
The few weeks before, i noticed my top end dissapeared, I stopped feeling that slight pull that i ussually felt when i got the header in from ~4900-6000 Rpms...Its just flat now..... So when i took my car into the dyno my graph looked like an earth quake.
I ended up with 128.6 Rwhp and 127.9 Tq [which is lower than it should be.... ]
From the sensors set up and all that jazz, i was running rich, and my spark is down....
Im thinking my spark could possibly be down, becuase..... ( The gasket that goes around the spark plugs leaked oil becuase i didnt put enough silicone around it. So oil leaked to spark plugs 1 and 4.
So my final thoughts are, If i get new spark plugs ( if needed ) should i get an Adjustable FPR or just get the stock one...
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Stock.
The stock ECU's fuel curve is not that bad, and the MAF compensates for more/less airflow...so lower fuel pressure throws thing out of whack.
Why do you think the one on the car is bad? Have you checked the fuel pressure?
- Brian
Kansei240sx
That what i am not sure about, How do you check the fuel pressure? and, i heard squezzing the return line on the FPR ( if it revs high then it needs to be replaced)
:: orion ::
You need a fuel pressure gauge...Summit Racing, or Jegs...either place will sell one for $20 or so.
They uses a barb fitting on each side...cut your fuel line right before it enters the rail, put the gauge there, see what it reads.
Specs are ~43.5psi with the vacuum line disconnected from the FPR, and approx. 34psi with the vac line connected, at idle.
If you squeze the line, it's not guaranteed to rev up...that's a bad method to test it.
- Brian
skatanic28
Car: 96 240sx
do you happen to have the dyno graph?the stock ecu maps are pretty generous with fuel at WOT, mine consistently went into the 12's when stock.
