adjustable camber
phanatikz32
Car: 1991 NA to TT z32 biatch!
i got my car aligned the otherday and dude at the shop told me that my camber was off and was not adjustable from the factory so i would need to buy an after market camber kit... is this true... if so how much are they... do i need front and rear... i dont know anything about camber and caster but my caster is also off... do i need an adjustable caster too? how much am i looking at spending to get my car in good shape as far as camber an caster and what exactly do i need..
Bohemiangod
Car: 1999 Chevy Camaro V6/5Spd and a 1990 Nissan 300ZX Twin Turbo!
I just had my camber fixed from an 3* offset. I bought some SPL front upper camber arms. ask your allignment specialist if you need front or rear. As for caster i believe you need adjustable tension rods, which are recommended when you switch the control arms. Stillen, SPL, and a couple of other companies make these. The camber arms are 290 for a pair or so and the tension rods are around that range as well.
phanatikz32
i already have tein adjustable tension rods... the dude told me that the caster was off tho?? maybe he didnt know what he was talking about... thats the last time i take my car to discount tires for an alignment...
phanatikz32
also are the adjustable upper arms universal for front and rear or... do i need front upper arms and rear upper arms... or... maybe i can take a pic of the report and post it up here and you can tell me if i need front, rear or both...
Bohemiangod
The front upper control arms look like I's while the rears are a giant loop that the coilover goes through. They are veryyyy different.
