C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Feb 08, 2004 7:58 pm
I'm running Cusco Camber plates on my Apexi' T-Max shocks. Most are designed to work woth OEM shocks. Most aftermarket shocks(non ride-height adjustable) are designed to work with the factory bearing plate. So consequently, most camber plates work with aftermarket shocks and OEM shocks. And they are sold seperately.
They are worth it if you need to change your camber setting. Particularly if you change them a lot. Perhaps dial in negative for the and put it to something more reasonable for the street. It depends. But it solved an immense understeer problem I had. My car was riding on the outside edge of the tire before. Now it rides much more evenly during a turn and is much more neutral. But before you go out and buy some to solve an understeer issue, confirm why your car understeers first.
