Adjustable camber kit?
chairmankaga
Car: 2007 M35 Base
1982 Alfa Romeo GTV6
When I got my '07 M35 last year I had an alignment done as it was pulling pretty hard to the right, fully swapping lanes in a couple of seconds. The shop was able to make some adjustments but said the front right camber was out of whack, causing the pull, but couldn't be adjusted unless I had an aftermarket kit installed. They estimated $800, with the parts costing $450 or so (Summit sells the SPC kit but I've found it cheaper on eBay). The Infiniti dealer wanted that same amount just to diagnose the problem. They seemed to think the subframe needed to be replaced. I'd sell the car before I went to that extent, though.
Looking at the front suspension shop manual the job doesn't seem all that hard for someone with reasonable experience. The struts don't have to be compressed, and the only specialized tools look to be a ball joint separator, which I have. Otherwise it's follow-the-numbers. Right?
Anyone have experience with the job or with the kit? I don't want to slam or stance the car, I just want it to not pull to the right or shudder at highway speeds. It's eating the tires and probably not doing great things for the rack.
My rack is also leaking slightly - in a year I've only had to add a touch of fluid, but it groans when I turn to the right if it's cold. That job is significantly more difficult as it's easy to damage the splines, at least in my experience. Still, worth the hassle while I'm in there?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Front camber is simple and easy, probably won't even need the spreader. Loosen the nut and prior to completely removing it, tap the arm with a hammer to get it to pop free, then completely remove the ball joint nut and hold onto that sprindle as it will fall free. All that is left is bolts holding arms onto chassis. If you haven't purchased the spc kit yet, I sell them as well and cheaper than either location.
chairmankaga
Car: 2007 M35 Base
Shot you a PM.
chairmankaga
Car: 2007 M35 Base
But I do wonder if maybe the original control arm isn't damaged. Bent, dinged, knocked out of alignment (bad bushing or bolt)... who knows. I do know the car was in a front-end collision at some point. Not a bad one - I've seen the repair invoice and it was all cosmetic - but maybe there was undiscovered damage. I'm taking it in for a transmission service soon so maybe I can get my regular shop to check it out again.
