Adjustable cam gears
dash
Car: s13 ca18
Nobody here makes a center disc and modifies oe cam gears to make them adjustable ??... as seen on some other forums with weak aftermarket support (which can actually be a blessing sometimes).I'm no machinist, but it would seem like a simple, straight-foward and inexpensive excercise.
as quoted from andiqqqq in 'cam guide' thread"Hi. I(n Poland we find out that if you move intake cam 1 tooth of pulley your torque will increase about 15 to 20 Nm and 5-7 HP. Torque is higher in a whole graph"
andiqqqqdo u advance or retard the intake cam. One tooth is 7.5°
Could be a worthwhile mod to 'snack on'.Some claim to put those dead exhaust cam to good use by timing them correctly = same results as the desirable/hard to get ca16 inlet cam.
The gears will still be usefull if you step up to performance cams
CadetLD
Car: 1991 Nissan 240sx Coupe
dont know about quality but OBX sells adjsutable cam gears on ebay
Nunook
after reading what that guy did with the tooth and stock cam pulley. I went out to my car and adjusted the tomei cam gears that I have. I was waiting to get some real cams, but i figured if it helps what the hell.
anyways stock JDM cams, I advanced the intake cam 5deg. and it definately pulls better in low to mid rpms(smoother). high rpms seem the same.
seems to run alittle richer according to my a/f gauge. but thats a narrow band so who knows how accurate it is.
