adjust the time Nissan Pathfinder VG33E
jerson3mendo
Car: Nissan Pathfinder 2000 4X4 SE VG33E
hello everyone!
I'm new to this subject .... and I need help ... I replaced the ignition of my Nissan Pathfinder 2000 (VG33E) engine and this is only + 0 -15 degreesbut which is no procedure to do? if anyone has any information which may assist me to make this adjustment will be well received
thanks from Dominican RepublicJERSON
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Did you replace the ignition switch or the crack angle sensor?
See the service manual on setting the CAS: Nicoclub.com/FSM
jerson3mendo
replace the distributor with a new
my question is if I have to unplug at any sensor, and / or perform some procedure to put the distributor to make 15 degrees
Greetings,Jerson
goon9
Car: 98 Frontier Xe, 96 Pathfinder Se, 90 Maxima vg5LSD
jerson3mendo wrote:replace the distributor with a new
Greetings,Jerson
It's pretty basic. You need to remove the dist. and advance it one tooth on the gear by just turning it a tad. Replace and throw the timing light on there. But I'm sure 2 weeks later you probably got it...
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
The FSM will likely have a procedure that goes something like:
Set crank to top dead center.Insert the distributor so the rotor is in some specific position.Lock down distributor.
