adjust Idle screw
sk8kei
I searched and read the repair manual, then looked under the hood couple times...I still have no idea where it's located...can anyone somehow take a picture shot... thanks
Axel Grungy
Car: 2001 G20 5spd
look at the intake manifold from the passenger side,find the bottom and follow it to the firewall, youll see a hole maybe the size of a penny with a screw inside. HTH
sk8kei
Is this where I can adjust the screw?? where is the screwalso what are those two electric plugs?
sk8kei
let me make sure, is this the idle screw? clockwise for lower the rpm, counterwise for bring up the rpm
sk8kei
any other method I could read the idle rpm or set it to 750? if my tachometer is not working and I don't have the inductive rpm pickup device....
stfuad
Car: '90 240sx Coupe, '95 3000GT
Follow what Axel said it's on the intake manifold, at the end, passanger side, inside a depression behind a hose...
