Already got them on. But, as I said, the car is pulling a little to the right, and YES, I already got an alignment. So, the question still stands.pandapants wrote:How about just new bushings?
think he means the studs that are on the ends of the tension rod that bolts down to the lower control arms...unless their the hollow tubes inbetween the bushing..adrians_s13 wrote:I'm sorry, but what "Pins" are you talking about??
The large bolt that goes in the center of the bushing.adrians_s13 wrote:I'm sorry, but what "Pins" are you talking about??
Do U know if the bushing is rubber or Poly? Also, is the bushing the same size as OEM? If it is, then I can replace the bushing with the Poly ones I have in my OEM TR; in the event the bushing is rubber.dtowndrifter wrote:Adjustable SPC ones are oem pins/screws..or studs...more like studs to me...
http://cgi.ebay.com/ebaymotors...ories
i like these cause they are much smoother since they have a rubber bushing...an not metal on metal.
It is the same size as the O.E.M one..I think the bushing is rubber i'm not to sure...i had these spc ones for a while about 8 months and one tore...so i burned the rubber out of the spc ones and added my energy suspension ones to it..the energy one fit on the spc ones..21nemesis wrote:
Great! Thanx!dtowndrifter wrote:It is the same size as the O.E.M one..I think the bushing is rubber i'm not to sure...i had these spc ones for a while about 8 months and one tore...so i burned the rubber out of the spc ones and added my energy suspension ones to it..the energy one fit on the spc ones..
I would think its just rubber come to think of it since they tore fairly easy...the energy ones are a great replacement for the spc bushing..and ride hella smooth...the energy ones will come with that hallow tube that goes through the middle of the bushing so you can bolt it up with the stock bolt..nice and snugg no play/rattle.
awesome i just broke my spc arm..i need a lil piece..Crazyirish wrote:Just an FYI. I emailed Enjuku Racing and they said they could special order the SPC pieces in about 2 weeks. Support NICO sponsors!
