float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Fri Dec 17, 2010 12:13 pm
I'm pretty sure that piece isn't welded on anyway, but an epoxy is used. If done properly, the JB weld should work. I used JB weld to fix a cracked coolant temp sender on my CA and had it like that for years w/o any problems. Make sure the surfaces have been roughed up with some sandpaper, and clean them really well. I personally like acetone to clean anything that I'm epoxying together. It seems to prep the surfaces really well and I've never had any bonding issues. I use epoxy A LOT to fix things and as long as it's properly prepped, and allowed to cure for long enough, you won't have a problem.
