elwesso wrote:Would a clogged filter cause the pressure check to come out bad, in which case the remedy could be just replacing the filter?
Yes it would, so would a clogged lineThe remedy <could> be to replace the filter ,or line, ( for chump change), IF you take the car in for a check the very first time you detect <any> slippage!Thats, why I said to take in in ASAP, when we talked about this 2 weeks ago.ASAP means today or tommorow but no later!!!!!!!
Because, low pressure (for which ever reason) can destroy your transmission in a few days.
Even if the seals had been bad, that still would have been a cheap fix, compared to ruining the planteary and clutch by running with low pressure.
Wes, it is possible, you went from cheap fix, to new transmission, in the time since you started the last thread on this subject.
Fred...
