Additional Spare Tire Hoist Installation
Green Pathy
Car: 1996 Nissan Pathfinder SE, 4X4
Hey all! I have a 96 Pathfinder SE with the swing out spare tire carrier, but i also want to install an additional spare tire hoist underneath the trunk/cargo area like some of the other pathfiners and QX4's have. I can find the hoist online, but i do not know how to go about installing it. Any ideas or diagrams? :help:
barnaclebob
Car: 2001 Pathfinder LE
2011 Altima SR
Dumb question but is there room for a tire under there?
Hawairish
Car: 2004 Nissan Pathfinder SE 4WD
There are two main parts: the hoist assembly, and a rest plate. The hoist assembly bolts to the crossmember under the storage bin with four M8x20mm bolts, and an M6x10mm bolt on the metal tab at the end of the tube. The rest plate attaches under the chassis behind the bumper with two M6x10mm bolts, and has a relief and hole where the tube is attached.
Rear chassis behind bumper where tube and rest plate attach:
The bolt under the plastic opening where the rod inserts is where the tube attaches. The bolts on either side (one about 12" away, and another about 3" away where my trailer wiring is attached) are where the rest plate mounts.
Crossmember and 4 bolts:
You will need those large rubber pieces. There's a RH and LH version (arrows on them point towards front of the truck), and they attach with a large plastic push clips. These, and the rest plate, are what the tire is pressed against when winched up. I assume you already have a jack and rod, though I think older R50s had a bottle jack, while newer have a scissor jack...the rod might be different.
If you have a hitch, you're limited to about 31"-32" depending on the hitch style/shape and where the receiver tube ends.
Green Pathy: if you're looking to get all the parts in shot, shoot me a PM. I have everything, except a use for them.
