Additional Key/FOBs
ArmedAviator
Car: 2012 Infiniti M37x
When I got my used car, it sadly only came with a single key/fob. I want to get two more. From what I've read, I can order the FOBs with uncut keys on Amazon/eBay or similar and take them and the car to the dealer to have them programmed and have any lock smith cut the key.
Is this understanding correct? Anybody know how much the dealer charges for this?
Ilya
Yes. I believe it's an hours labor (~$80) at the dealer, but don't quote me on that.
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
1. Might be cheaper at a Nissan dealer
2. Some locksmiths have the ability to program intelligent keys - could me make specific (they would need a Consult 3/4 with the key programming module) or some other fancy computer set up to do it, though. But, advantage is one stop shopping: physical key can be cut and the intellikey programmed.
Big_Tone
Car: 2011 Infiniti M56x (White w Java interior; Tech Pkg)
PPE Headers; HPS Intake
Custom 2 1/4” exhaust with Jones Exhaust X-Pipe
Infiniti Sport mufflers
You are correct. You can buy the key online and have it programmed at at dealer. The Infiniti dealership I use charged me $65 to program. I still need to get the key cut, though. When buying your key make sure the FCC ID on the one you're buying is the same as they key you own, or they won't be able to program it. You can find the code once you slide out the key.
mrnix
Car: Currently 2012 M37X, Malbec Black
Formerly 2004 Infiniti G35 Sedan
How much does it cost to buy a new key online? Anyone have a range?
Big_Tone
I bought mine on ebay for $80
Larz
Car: 2019 Q70-L RWD
The dealer will likely be able to provide an extra fob for you, program it, and cut the metal key as well. However, it will cost you a bloody fortune. When my windows were tinted, they left my fob on the roof of the car when they called me out to drive it away. I was told that the fob was in the console. I drove it onto the road and the fob rolled off the roof and into the street. Then the "NO KEY" light came on. I did a U-turn back to the shop and their mistake was discovered. The fob was found in the road, crushed by a following vehicle. They sent me to a locksmith to get a new fob at their expense.
The locksmith had to program three different "matching" fobs before he found one that would actually work. I would hate to have to return 3 different keys back to an Ebay seller just to find one that really works on my car.
That is why I don't recommend buying a fob online. Perhaps it took three different fobs because of the locksmith and not because of the actual fob, but if you buy online and this happens, you have to keep returning fobs through the mail until you get the fob that actually will work reliably.
