philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Sat Jun 28, 2008 2:03 pm
Hello, and welcome to the forums.
There are significant differences in the audio system options between the US and Canada. Canada gets a mid level audio that is similar to the full BOSE system (6CD, MP3, steering wheel ctrls) but less the amp and additional speakers. XM sat radio is also an option for Canada. In the US, there is only a base system or the loaded BOSE system complete with XM SAT radio.
I have quickly scanned the factory service manual, and it appears the mid-level audio has the option of XM SAT radio. There is an empty 12pin connector on the rear of the head unit that the XM SAT radio plugs into. You would have to check to see if your head unit has this connector. If it does, You would then require the XM receiver and you would have to replace your radio antenna with one from a SAT radio equipped Rogue that contains both the SAT radio antenna and regular radio antenna.
Your only option is the dealer for these parts. Unfortunately it won't be cheap. A quick scan of online parts listings:
XM SAT tuner: $245 USDMounting hardware: $25 USDSAT antenna: $90 USD
You can try purchasing from a US dealer, but I do not know if the sat radio subscription can be obtained for a Canadian address.
Good luck!
