Post by marshal » https://forums.nicoclub.com/marshal-u159743.html Wed Apr 28, 2010 7:04 am
Post by philipa_240sx » https://forums.nicoclub.com/philipa-240sx-u68765.html Wed Apr 28, 2010 7:50 am
The filter, etc you described earlier was likely not the correct one for the application. You require a line output/level converter (LOC) that accepts speaker level inputs and converts to line level the amp can use. It connects directly to the L & R speaker wiring.Can anyone recommmend an easy solution to split the sub signal without installing an aftermarket head unit.
Post by philipa_240sx » https://forums.nicoclub.com/philipa-240sx-u68765.html Wed Apr 28, 2010 7:54 am
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
