mcdoken »
https://forums.nicoclub.com/mcdoken-u122595.html
Thu Jun 04, 2009 6:04 pm
It's easy to check. Remove the top trunk finisher cover. The tuner goes in the upper right, just below the rear parcel shelf. You will see the connector there.
To install the tuner is easy. Just plug it in. And secure it.
If the roof antenna is not installed (does it have the shark fin on the roof? - I doubt it), it will take some time and work to install the factory set-up. Better to just use a small after market antenna which can go on top of the rear parcel shelf and be almost invisable. There are also other options that are easier and cheaper than installing the factory antenna.
