I was hunting around on here earlier for some wiring diagrams and found your forum to be very useful!
I am from Australia where we call the Versa a "Nissan Tiida".
Anyway, I thought I would contribute something to the forum - my mum has a Versa / Tiida and it had hand crank windows in it - unfortunately she has had major spinal surgery and finds it hard to use the stock window winding mechanism - so I bought a door off a guy on ebay - stripped it all and fitted the electric window internals to a non electric door.
Parts required :
1 x electric window door trim.
1 x electric window window switch controls
1 x electric window lift mechanism.
1 x electric window door wiring loom.
Basically all I had to do was strip the new wiring loom, (LEAVE THE OLD LOOM IN THE DOOR)
Run the following 3 wires into the body of the car :
PINK
DARK BLUE
BLACK
Wire them up as follows :
Pink : constant 12V (batt)
Black : GND (ground)
Dark Blue : accessories (switched 12V)
And the drivers door now has a working power window.
Here are some photos :
The mechanism to lift the glass is exactly the same for the hand crank assembly, except it has a motor, so it just bolts out / bolts in.
You can use the same glass.
Sorry for now taking more photos
