Adding power sub in trunk
SilverCi
Car: 2006 M45
I went to a local audio shop and had them listen to my system. The bass is loose and lousy, we all know that. I asked about switching out speakers and he didn't think that would make too much of a difference for the money.
what he told me to do was put an enclosed sub in the truck with a dedicated amp, and tie it into the factory system. then turn the base down on the BOSE system all the way.
He said this would make a huge difference on the system. this will probably run me from 500 to 750, you guys think that is a good price? Worth it to you guys?
jbillion
Car: 2004 M45 Premium Package
No mods, just keep it clean.
2008 Altima 3.5 SL CVT
Sounds like an OK price, but completely depends on the type of sub and amp he is going to install. I looked into getting the JL Audio everyone was raving about on here, but the $2K sticker shock to install one sub with an amp was too much.
skim35
Car: Infiniti M37 Sport
Depends on the amp and sub you get?? but if you want to really feel the bass come though I had to upgrade from my 300watt amp and Sub to a 600watt amp and better sub! cuz the 300watts wasn't cutting it especially with the M's thick back seats and insulation! so now my 600watt phoenix gold amp and JL audio W6 12in sub puts out enough bass for my taste in music! I also got a overdrive unit which increases the volume of your factory head unit because they are weak in wattage!! so you might want to add that in also overdrive or a epicenter unit, but the epicenter is much more $ and all it does is give you more BASS so you will have bass listening to anything country, opera haha whatever! If your in So. Cal i have my previous amp and sub if you want to buy it kicker 12 comp and a Fosgate 325watt amp. Good luck
SilverCi
Car: 2006 M45
Thanks guys. The sub was JL not sure about amp. Not sure about wattage either, I guess those are important questions
I don't want so much bass i'm heard a mile away, I just want clean, tight bass.
I'll look into the overdrive too.. thanks!
skim35
Also make sure the box thats made for the JL is made right! to that subs specifications very important!
07sportm35
Car: 2007 Infiniti M35 Sport
skim35 wrote:Depends on the amp and sub you get?? but if you want to really feel the bass come though I had to upgrade from my 300watt amp and Sub to a 600watt amp and better sub! cuz the 300watts wasn't cutting it especially with the M's thick back seats and insulation! so now my 600watt phoenix gold amp and JL audio W6 12in sub puts out enough bass for my taste in music! I also got a overdrive unit which increases the volume of your factory head unit because they are weak in wattage!! so you might want to add that in also overdrive or a epicenter unit, but the epicenter is much more $ and all it does is give you more BASS so you will have bass listening to anything country, opera haha whatever! If your in So. Cal i have my previous amp and sub if you want to buy it kicker 12 comp and a Fosgate 325watt amp. Good luck
Great advice skim. Does the overdrive have a "aux" input as well?
skim35
Im not sure?? all I know is that it was hooked up to the Amp..here is what I got and the place I got it at.
http://www.woofersetc.com/p127...r.htm
Hope this helps!
mcrews
Car: 2002 Q45 Sport
SilverCi wrote:I went to a local audio shop and had them listen to my system. The bass is loose and lousy, we all know that. I asked about switching out speakers and he didn't think that would make too much of a difference for the money.
first, it really helps if you tells the yr of the Q. Just put it over in the avitar where you have your town.
in the 02 F50 body, there is an amp but it powers all the speackers not just the sub in the rear window shelf.
second, the trunks are sealed and insulated (infiniti Q - top of the line luxury) so you have to have some way for the base sound to get into the interior......or your just buyin THUMP!like the previous poster who had to double up in watts.
I run A KENWOOD ksc-SW10 POWERED sub. it maxes at 150 watts but I run it IN the car. actually in the open space created by the armrest being down.It fills in the bass nicely AND i dont have to run it at MAX.
I came right off the rear deck speaker
it has a remote power on/off also freq and power knobs that sit in the top armrest.
SilverCi
Car: 2006 M45
I have an '06 M45, not a Q. But thanks for the post, that looks great.
Will I have the same problem with the M's trunk?
mcrews
Car: 2002 Q45 Sport
SilverCi wrote:I have an '06 M45, not a Q. But thanks for the post, that looks great.
sorry,yes. the trunk is insulated and sealed.
A bass speaker is pushing air. on that little powered speaker in my backseat, I can feel the air when there is a strong bass. I can hold my hand 6 inches away and feel it on almost any song. That's why the cars w/ the big speakers rattle. It is unavoidable.So you have to have an exit port for the sound to go thru into the car. you could cut up you rear tray but it's hit or miss.
I had bought a very thin black material...almost mesh to cover the speaker so no one would see it. the mesh would dance infront of the speaker. when I taped it down....it 'rattled and buzzed' because the air was blocked.
good luck
InfinitiMe
Car: 06 M35x Blue/Wheat
SilverCI, I would seriously consider having them install a separate control for the sub.
I have the bose 8 speaker. I added an 8" W7 sub and JL 500/1 amp and had it the way you're planning to in a custom enclosure made by the audio shop. They told me to keep my bass to 2 notches below half way. I have it at 5, sometimes 6 or even more depending on the song. But the speakers really need to stay at 5 or 6 without having to worry about the sub. And if they hook it up the way you described, you'll be controlling the sub and the speakers from the stock head unit.
Also, I would recommend getting at least your trunk dynamated. It makes a difference. I got my entire M35 dynamat'ed. The sound is VERY good for a stock system with only a sub and dynamat added. You can feel the bass in both front seats.
07sportm35
Here is a picture of my setup...
radigan
Car: 2013 M37xS
http://www.rad1gan.com/stuff/DSC02876.JPG
this is my setup, needless to say i am more than pleased.
New2Import
Car: 06 M45
Dont think so. The Clean Sweep by JL does. Im going that route with 2 8s and all new door speaker. This Bose system is really pitiful!!!!! The Infinity system in my wifes R/T is two times better than this Bose crap. They need to stick to home audio. Leave the car audio to the pros.
