MinisterofDOOM wrote:As far as I know, yes, you'd need the antennas.
If you feel like devoting the time, a dash-mount retaining the stock CD-changer definitely sounds ideal. What did you have in mind?
Do you know if the wiring is the same between from-factory nav and non-nav cars? Meaning are all the connections for OEM nav going to be there for you already?
Whether or not I can keep the in-dash CD changer is greatly dependent on how much work/money it would take to swap it with the single din stereo and cd changer. (I know right now the trunk isnt wired for a cd changer, so I'd have to run a ton of wires back to it or buy the connectors/wires from a dealer.)
To answer your 2nd question, I honestly have no idea. Truly, the only wires that I'd need would the wires be to connect the nav system to the battery, antennas, screen, and possibly the stereo if I really want the voice guide nav part of the system to work. As long as I have the connector that goes into the back of the nav system, I can splice wires on to it and connect them where they need to be (battery, antennas, ect.)
Another thing I was unsure of was whether or not the different stereos are plug and play. Will the single din stereo plug right into the harness from the double din player?
