elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Jan 05, 2010 12:45 pm
I will be pretty impressed if you get this thing to work as it is OEM, let alone adding features to the stock system.
the thing that concerns me is what kind of signal the remote is sending, and what kind of signal the car is expecting to see. my guess is you'd need to modify the remote and the receiver, not just the receiver..
You'd probably be better off to design and program your own receiver than you would be to somehow "count" the number of times you pressed the unlock button. Also, theres another button on the remotes for illuminating the interior, that you might be able to reroute its function to something else..
Lets say this:1. You press the lock button once, and that locks all doors (stock)2. Press and hold the lock button, and it rolls up all the windows (replacing the function where it activates the car alarm)3. Press the unlock button once, and it unlocks the drivers door (stock)4. press the unlock button twice, and it unlocks all doors (stock)5. Press and hold the unlock button, and it rolls down the front windows (stock)6. press the "illuminate button", and it rolls down the back windows.
I think replacing functions is going to be a much easier approach, but by far the first thing you need to do is get it working in an as-designed fashion FIRST.
BTW, if you think you can pull this whole thing off in 1 day, from ripping apart the interior, doing all the wiring, and putting it all back together, you are on crack....
