Adding Keyless Entry Maxima/I30 4th Gen, Help !
Sam Ali
Car: Infiniti I30, 97 , AT. MEVI
I am adding Keyless Entry Module to my I30, It does not have keyless entry. I installalled the keyless entry module (LCU05) that I got from someone, and it installed and mated perfected with available connectors in the right hand side of trunk beside the power anttena. However, when I tried to reprogram the remote the hazard light did not blink as the 6 times insertion procedure. Brought them to a nissan dealer and using consult all tested ok (IVMS commmunication test).
My question, is there anything I am missing ? Do I need a different BCM that support keyless entry ? Or ??? Plese help.....
Thanks
NISTECH
The programing proceedure is a bit tricky, I have physically shown some people many times and they still cant seem to get it in the mode to program.
When you go to put it in program mode[key in and out till hazards flash] dont count the insertions and stop at 6. just go in and out of the ignition, be sure to fully withdraw and then fully insert the key untill the lights flash this is a pretty rapid in and out procedure to beat the timer from when you locked the doors with the master switch after you got in and closed the door.
Sam Ali
NISTECH wrote:The programing proceedure is a bit tricky, I have physically shown some people many times and they still cant seem to get it in the mode to program.
I thought I have done that. but will try again.... and post the result...
