ArmedAviator wrote:Yep, engines are awful at efficiency. As stated above, gasoline engines are somewhere around 15-25% efficiency. The remaining energy is lost as heat - mostly through the exhaust and radiator.
Diesels do a bit better because of their much greater compression ratio.
Electric motors are the way of the future for their increased efficiency (and torque, and size, and reliability, and ease of manufacture and maintenance). However, we need a new type of battery as the precious metals used in current battery technologies are more finite than fossil fuels. It'd also be wise to charge these cars with nuclear and solar energy as much as possible (preferably molten salt reactor, being the most cost-effective method and requires the least materials).
As to the OP's post.....
All hogwash. Nothing to be gained here.
In all fairness an internal combustion engine isn't too bad compared to other thermal engines (steam cycles, gas turbines, etc)..
HHO is an interesting idea, but probably not worth it especially considering it's a somewhat dangerous thing to be messing with for the DIYer...
Molten salt reactor is interesting but there's still a lot of engineering questions to be worked out there... Every flavor of that I've seen is using fluoride based salts, which are noticeably corrosive. The breeder reactors I've heard of uses fluorine to process/regenerate the salt and carry out the fission products. Conceptually the whole thing is pretty good, but there's noticeable challenges particularly on the materials side..
Bubba1 wrote:Actually, I think hydrogen fuel as a primary fuel for vehicles is a stronger possibility in the near future as it doesn't pollute, and there's even more of it. Given how big our country is and how far Americans are willing to commute/travel by car, and the variety of climates, I suspect we're farther away from a long term mass conversion to electric cars (which work best in mild climates and short mileage requirements) than hydrogen. I can see electric doing well in certain areas/circumstances, but not universally.
The only problem with hydrogen is that at best it's energy neutral, meaning it takes as much energy to create it as it then can create. Not to mention since it's not easily condensed, you're stuck with high pressure tanks which people tend to frown upon. Natural gas is probably a better source of fuel if you're talking gasses that are difficult to condense into liquid.
Overall, I don't think we'll ever completely get away from liquid based fuels for transportation. We may be able to eliminate it in some areas, but you've got airplanes, boats, and heavy equipment that are by nature larger energy users which makes the challenge exponentially more difficult. Fact of the matter is liquid fuel is easy to transport, the infrastructure is already there, and pretty energy dense for what it is.
