You are probably out of warranty, so you'll probably have to pay for it, but go to the dealer and have them perform the update. It will help quite a bit.I forgot what it's called, but maybe someone else here can volunteer the info on what it is.my first q45 wrote:Can these cars be hyper chipped.It has 340 HP but doesn't act like it.This was a weak point in all the reviews about this car.A whole lot of HP but should take off faster and doesn't.Any ideas how to improve the pop off the line?
That's not true. Read the particular ITB quoted in previous posts. Perhaps your VIN falls outside the range, so in that case you already have the update.my first q45 wrote:Well that was a bummer. I called the infiniti dealer and they said no update is available for the ecu unless the check engine light is on?
