Adding Factory Tach
mrecoolgar
Car: 1990 Hardbody Reg Cab 2WD 2.4 5SP
Surprise surprise.
I traded gage clusters on my 1990 2wd and my 1990 4x4.
When I drove the 4x4 I noticed the tach did not move.
Odd as it worked on the other gage cluster.
So I started my 2wd and . . . the tach worked.
Apparently my 2wd was wired for a tach even though it never had one from the factory.
Since it didn't work when I installed it years back I thought I needed to wire it in somehow.
If you want to add a tach give it a try.
Mine had the connector in the dash for the tach as well as the clock.
osegundo
Car: 1989 2.4L Nissan D21 4x4
Mine only has the needle for my speed!! Do you know where I can purchase tack and clock!?
RT22
Car: 1991 nissan hardbody
Most wiring harnesses are wired for all options, cheaper to use one harness and only use the plugs the truck comes optioned for. Many cars and trucks have empty plugs hanging loose that are not used on that particular model.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I have a cluster with a tach if anyone wants to buy it. It reads 155k and worked perfect till the day I removed it from my 96. If you use it in an older truck with no air bags you will have to remove the air bag light. I've been asking $40+shipping for all my clusters.
osegundo
Lucky you, I installed one with a tack and its not moving! The clock works, I'm thinking the connector isn't making good contact!! I'm hoping its that!!
mrecoolgar
The tach is most likely no good.
