maxnix wrote:Put fan on top of hood to draw air wout when stopped. When not stopped, could be a problem.
chicos240 wrote:You could just use a turbo timer. It will keep your engine running and the fans going for 5-10 minutes while everything cools down. In turbo world we use it so the oil doesn't SIT super hot in the turbo. If the TURBO is super HOT and the oils SITS because the engine has stopped it becomes cooked in there and can seize your turbo.
MinisterofDOOM wrote:I wonder how effective that would really be...
Not trying to shoot down the idea, just thinking out loud. The car's not moving, fans can only be located at the radiator...not really anywhere for the heat to go. Fans work at a stop when the car is running thanks to the fluid coolant system with radiator. Coolant is not flowing with the car off, so the fan would basically have the job of cooling off a giant block of aluminum. If you had a way to draw air OUT OF (rather than just into) the engine bay, you might see some kind of useful benefit. But just turning on a fan after shutting down the car doesn't seem like it would be effective. Might have been kind of effective in the Z with its much more open engine bay, but even then the same issues apply.
Q45tech wrote:Why not just create a time delay relay so when you push a button [in summer] the condenser fan comes on for an adjustable 3-5-10 minutes?
On low speed it probably only consumes 15 amps? Make sure battery is good and check frequently.
A pop up vent in hood would be interesting.
I've noticed that the 94-96 under-plenum hoses are a lot more supple than the 90-93 hoses. More brittle and broken connectors on the 90-93 too. The 94-96 grill let's a lot more air to the upper engine area than the badged and grillless 90-93.Paul Wall wrote:.....I also remember mike (Goody94Q45) saying that it would beneficial to say the least, But I can't find that topic.......
After looking at the FSM and going by what you say about the ECU. I have concluded that it is 2X times as hard to do this on a 1994-1996 Q45 rather than on a 1990-1993 Q45.Q451990 wrote:I vaguely remember a post from a long time ago... maybe even on the yahoo board, about sending a ground pulse to a pin on the ECU that would keep the AUX fan on for a period of time after the car was turned off. It only worked for that one time, so you would have to have some way of grounding that pin each time you turned the car off...
Like I said, it was a long time ago... maybe this will jog someone's memory...
Weird I thought about the same thing as I was taking a wizz. I want to see where exactly the active fan is and if any air could possibly get in there.Q451990 wrote:If you didn't want to use the auxilary fan, you might be able to rig something up in the active cooler space in front of the left wheel well.
Heath
I agree totally... on the one 94 Ive done a plenum on only the hoses I cut really needed to be replaced.goody94q45 wrote:
Yes, open the hood when in the garage, and the heat "magically" rises and leaves the engine bay!elwesso wrote:if you really are concerned about it you should just open the hood...
well give me a lesson then. were u understanding what i said.... im sure u did that would just be silly. so what was it i missing then. grill or not its right there thats all. so im all about learning things so teach me something.there really must not be a reason for grills or airdams then...good to know...... thermo what??Q45tech wrote:Why would you imagine that a grill makes any difference in air flow into engine compartment?I suggest a few course in thermodynamics.
That's a good point. The thermostat opens gradually (so it's not like all of the cold coolant flows into the engine at once) - but still, there has to be a pretty major temperature swing in freezing weather.qship96 wrote:Engines get a slug of ICE COLD coolant {sometimes below 0 degrees in the north} every day when one starts their car on a winter morning and the block heats up enough to open the thermostat and allow the still ice cold coolant from the radiator to flow into the now hot block!!!!!!
