Added sub & amp to A/C
All things Altima Coupe.
midgets
Car: 08 Altima Coupe' 3.5SE
Just finished up adding a 10" Kicker sub and Kenwood amp to my 08 Altima Coupe'
let there be BASS
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
vballer22
Car: 2008 altima coupe 2.5s
Nice! Who built the enclosure?
And ATHF rules.
wrench78
Car: 2008 Altima
vballer22 wrote:Nice! Who built the enclosure?
X2. Love that enclosure. will it fit a 4 door?
ThatGuyRoger
Car: 08 Super Black Altima Coupe 2.5S
looks great
i would also like to know more about this enclosure
midgets
Thanks, I built it myself. It's my first fiberglass enclosure. Over all it wasn't that hard to build but man is fiberglass work messy. I read up on building them and every one said cover everything and they are not kidding. You never know what you will touch with a glove covered in resin (like resting your hand on the tail light for balance). I'm very happy with the finished product other than the carpet, I used some left over black from a previous sub box instead of getting charcoal to match.
It's molded from the coupe trunk so I don't think it would fit the 4 door. But if you have some free time you can build your own.
long live CARL
ThatGuyRoger
thats awesome that you built it yourself, looks real good
wrench78
Car: 2008 Altima
Ok, thanks for the info. Deff. did a great job.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Boston makin it happen! nice work!
quick_shift
Car: '08 A/C 3.5SE 6MT - Dark Slate
looks good!
noshift
Car: 07 altima
im probably just an idiot, but how did you mount your amp to you backseat? i mounted mine on my seat and it keeps coming loose.
rjdmmfl1
noshift wrote:im probably just an idiot, but how did you mount your amp to you backseat? i mounted mine on my seat and it keeps coming loose.
you have to use metal , self tapping screws, and screw it into the metal portion on the rear of the seat...
maxentropy
Car: '08 Altima Coupe 3.5SE
Looks good midgets! Do you have the Bose system or standard? I'm curious if you have the Bose if you disconnected your subs or not.
midgets
Thanks, I have the Bose system and I did leave the stock subs wired. One reason was I couldn't get the stupid plugs off the speakers and also figured more bass, if it sounded bad and it doesn't then the factory subs would get unplugged (some how).
maxentropy
So midget, with the aftermarket and factory subs both going, you still get clean, clear bass? I'm under the impression there would be a slight delay from one to the other and it would be muddy...
notaverage
Car: Altima Coupe 3.5 SE w/ tech pkg and VDC. Precision Grey
You have the same setup as mine! Kicker 10" with a kenwood amp. I don't have the fiberglass enclosure though
Wish someone would make these enclosures and sell them on NICO!
LittleMan
Car: AC
The box is nice and clean but do you think it would sound better if it had more air??? I have made several boxes before and that box look a little small for the speaker.
Looks good tho...
