In any case - with the new LEDs they don't pull much current and I think they look cool.
I installed the DRL1 module from http://www.webelectricproducts.com. I was very impressed with WebElectric's service. I put my order in on their web site on a Friday evening and got a confirmation email at about 9:00 that night. It shipped out on Saturday and I got it on Monday - as well as a follow up email and a "thank you" mint in the bag.
This module illuminates the turn signal (brighter) portion of the front signal/park lights any time it's getting 12VDC from the car. When the turn signal is activated, that light turns off and then starts flashing. After a second or two of the turn signal being switched off, that light turns back on steady at full brightness. The other light stays on during the signal. There's a synchronize wire that can be grounded if you want to kill both DRLs during a signal, but I opted to not use it. When the the park lights/head lights are turned on the DRL system deactivates and everything functions normally.
To make sure the installation was more complicated than necessary, I went to the pull-a-part and clipped off the harness to both front turn signal assemblies and to the windshield washer motor connection off of a '92. The washer gets switched 12V and is on a relatively robust circuit. I also snagged a plastic relay box that was mounted behind the right headlamp assembly that appeared to feed the auxiliary fan. This relay isn't located there on my Q, but there was a threaded hole in the same place, so I was able to use this box to hold the DRL module which adds some protection and makes it look OEM. I used the connectors to make up "T's" that plug in between the factory harnesses so that I didn't have to cut or crimp in to any of the existing wiring. Everything is soldered, sealed with heat-shrink tubing or liquid electrical tape, and then wrapped in electrical tape. My overkill added a good hour or two to the project vs. the supplied wire nuts and crimp on connectors.
The only thing I'd like to find is a place under the hood that provides ground only when either the engine is actually running, or when the transmission is in drive. Right now the DRLs are on any time the ignition switch is on, even just set to ACC. That's not a big deal since the LEDs only pull about 270ma, but it would still be nice for them to not be on except when the car is actually being driven.
I'll take some pictures and post them soon.
Heath
