Jemdawg »
https://forums.nicoclub.com/jemdawg-u48609.html
Mon Oct 16, 2006 6:16 pm
The sub that comes with the audio package they sell is just an 8" Rockford Fosgate. I'm not sure what line it's off of, and it's probably worse than their worst aftermarket sub. Do yourself a favor and buy a decent 8" sub that you can amp up to at least 400w. You can make the spot they would use for their sub work for that one without taking up much space. I have a 12" viper in my trunk and it takes up almost half of it.
As far as a wiring harness, there isn't one out yet, but I'm sure it will follow soon after the rest of the 2007 line is released. However, an aftermarket deck can be put in easily by splicing into the wires. I would suggest putting a new deck in with 4 component speakers and the sub, otherwise you wont have a good balance of sound. Putting the sub in without a new deck is a little tricky; I did it myself, but I had to use a HILO adapter and splice into the right speaker, which makes my sub a little less powerful than it could be with a new deck.
