Add me to list of leaking headgaskets!
c-rad
Car: 1991 Nissan 240SX w/CA18DET
But, before everyone is like "OMG!" I don't trust the torque wrench I used at all. It was my friends old Advance Auto Parts special. So tomorrow my friend is bringing by his craftsman so I can retorque them. I HOPE that solves it. Otherwise I dunno why it would leak.
boost_boy
c-rad wrote:But, before everyone is like "OMG!" I don't trust the torque wrench I used at all. It was my friends old Advance Auto Parts special. So tomorrow my friend is bringing by his craftsman so I can retorque them. I HOPE that solves it. Otherwise I dunno why it would leak.
If it's leaking under the head nearest the #4 cylinder on the exhaust side, re-loosen the bolts and torque them in sequence to 86psi. What washers are you guys using with your ARP studs? I hope this fix your leak.
Dee
originalsin
doesnt arp include washers with the studs? if so id imagine they are using those? but yea, has anyone got the cometic to not leak? seems like they may be defective? idk
c-rad
boost_boy wrote:If it's leaking under the head nearest the #4 cylinder on the exhaust side, re-loosen the bolts and torque them in sequence to 86psi. What washers are you guys using with your ARP studs? I hope this fix your leak.
Dee
Yeah, thats where it is leaking, and that's exactly what I was planning on doing. I am using the washers that came with the studs. Stupid $hit.
boost_boy
Don't use the washers that came with the ARP studs. The nissan ones are the ones you want to use. Don't ask me why as I don't feel like trying to answer it, just take my advice and trust me on this one.
Dee
c-rad
boost_boy wrote:Don't use the washers that came with the ARP studs. The nissan ones are the ones you want to use. Don't ask me why as I don't feel like trying to answer it, just take my advice and trust me on this one.
Dee
WTF? Ordering those damn things will take forever and will probably cost me like $40 (the way Nissan charges out the *** for stuff like that). Wish I kept the originals now...
originalsin
if the ka ones work i should have a set for u....
float_6969
Has anyone (or more appropriatly, everyone) thought to contact Cometic regarding this? Perhapse they have a manufacturing defect that needs rectfied.
rico05
Car: 1992 RMS13 w/ CA18DET
Why in the hell would a freshly prepped CA have the same leak as my (and others) 50k old setups? Can someone explain to me why this is a problem issue for these motors?
I know in my case, the stock hg had a sizeable crack (no signs of detonation, and the exhaust valves were clean) in the area of my first leak, and now....everyone has the same problem area. WTF?
capwred
damn i hope mine dosent leak.only time will tell.i had the head and block resurfave like i was told to do.but im reuseing the factory head bolts.
f s t caz
Car: VG30ET D21 Extended Cab Pickup
leaking as in leaking coolant, oil or air?
c-rad
rico05 wrote:Why in the hell would a freshly prepped CA have the same leak as my (and others) 50k old setups? Can someone explain to me why this is a problem issue for these motors?
Check out the other ARP thread Dee made... I am sure its because I only preloaded the studs and never retorqued them. I'll let you guys know tomorrow evening what the deal is.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
its all about the digital tech wrenchs from snapon, especially when you get them free.
c-rad
f s t caz wrote:leaking as in leaking coolant, oil or air?
oil
rico05
But see, what if you are tunning stock head studs? There should be no reason to heat cycle them or anything. And in all reality, the stock gear should be fine for me (and for most of us).
boost_boy
rico05 wrote:But see, what if you are tunning stock head studs? There should be no reason to heat cycle them or anything. And in all reality, the stock gear should be fine for me (and for most of us).
And the stock gear works for me as well. I think the problem with the studs are that you guys may have the wrong part # as well.
Dee
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
boost_boy wrote:And the stock gear works for me as well. I think the problem with the studs are that you guys may have the wrong part # as well.
Dee
Mr Boost, can you e-mail me, got a few questions. [email protected] PM function on this board right?
/Mike
