Asmara »
https://forums.nicoclub.com/asmara-u262227.html
Sat Mar 19, 2016 5:59 am
I'm new to Rogues so can't answer your question directly but do you already have electrically adjustable mirrors?
If so, the Rogue is likely pre-wired for heated mirrors. Many cars are since if they are running cabling there anyway, it is only a single additional wire and cheaper for the build to have a single harness. In that case all you would need to do is buy the new heated mirrors and swap them out with the old ones. No other changes and they will turn on when the defrost is on. I've done this in other vehicles in the past. Again I'm new to Nissan but with my Toyota, you could buy the mirrors from Toyota already painted at the factory.
