Adaptronic Standalone Engine Management Plug and Play System
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
BoundaryEngineering
NICO forum members! I just got permission from Greg @ NICO to offer you guys some engine management options for the RB32/RB33 RB25DET. The Adaptronic is full plug and play system. I have uploaded the instructions here so you can check them out. http://www.boundaryengineering.com/RB25DET.pdf
From the sales brochure:
The Adaptronic is a fresh new look at engine management. It gives all the stability and function that an OEM computer has, but opens you up to unlimited control of your motor. This system gives you all the functions to get the most out of every turn of the crank including complete fuel and ignition control, full sequential ignition and injection, correction maps for water and air temperature, starting corrections for the cold of winter, and summer of the Sahara. These are what every engine needs to survive but the Adaptronic also steps up to the plate when it comes to accessories. Control virtually any 12 volt component! Nitrous stages, water injection, exhaust cut-outs, supercharger clutches, variable valve timing, variable intake charging, it is all at your finger tips.
Now that you’re generating all this power what about putting tire to asphalt? The Adaptronic utilizes, and fully supports traction control, launch control, flat shift (WOT shifting), boost by gear, and full closed loop electronic boost controller management. With these sets of tools at your disposal, this ECU will not only make your car a dyno king, it will help you nail your 60 foot times to get you down the 1320 first, and it’ll help push you through the apex, and snag the heat. This isn’t just engine management, this is vehicle management. Welcome to the Adaptronic.
Kit contains:1 Adaptronic e420c ECU1 Map sensor of choicePlug & Play Harness
http://www.boundaryengineering...e.php
I also encourage you to take a browse around the site, the Miata ECU section has some interesting information on it as well in its sales brochure. I personally use this unit on my vehicle and its been great. If we get enough interest I might be willing do some special pricing. Thanks for checking out the post and hope to hear from you soon.
BigJuiceSr20
Car: nissans, mazdas, soccer
The Adaptronc is a nice system! I just installed the e420c on my SR20DET and set it up for full sequential ignition/injection. The VE based fuel tuning and target AFR self tuning is a nice feature as well. I haven't used the adaptive learning portion as yet but I am highly satisfied with this sytem.
I just purchased another e420c and PnP harness for the RB25 cause I have an S14 that 's getting that motor.
Base maps are available for these motors as well from Adaptronic so you can get the car running and then you just have to fine tune. I do recommend using a wideband in tandem for the initial tune.
Return to “GTR Forum / Skyline Forum”
