Adaptive headlights ?
1GR8M56S
Car: 2013 M56S
Has anyone had any problems with the headlights turning?
I notice the passenger side working but the drivers side I can't really tell if it is, I recently changed the bulbs and I don't know if something would be obstructing it.
Larz
Car: 2019 Q70-L RWD
The bulbs, as you know, will only go in one way to make them fit flush in the socket. You're car seems too new for the AFS motor to need replacement. Try placing your car with the headlamps facing a wall at night, or in your garage with the door down. Turn the steering wheel in both directions and you should see them move.
1GR8M56S
Car: 2013 M56S
Just did it only the passenger side is working
SmoovC
Car: '06 Infiniti M45 Premium, Brakemotive, H-Techs, KYB's, USA-Spec PA15-INFI w/ BT streaming, Kuda cell mount, Magnaflow exhaust. (CAR SOLD)
Current: 2012 Infiniti M56S, Harbour Blue, 4 pc Aero Kit
The left one is only active at speeds over 16mph; IIRC from the owner's manual.
1GR8M56S
Car: 2013 M56S
Well that would help me alot if thats the case, I'll try it tomorrow on a back road. I hope thats the fix, will let you know tomorrow, thanks.
SmoovC
As per 2-37 in the owner's manual:
The AFS will operate:
. when the headlight switch is ON.
. when the selector lever is in any
position other than P (Park) or R
(Reverse).
. when the vehicle is driven at above 16
MPH (25 km/h) for the left-side headlight.
Note that the right-side low beam
headlight will swivel but the left side
will not swivel when the vehicle is
below 3 MPH (5 km/h) and the steering
wheel is turned. The vehicle must attain
a speed above 16 MPH (25 km/h)
before AFS activates the left-side headlight.
1GR8M56S
Car: 2013 M56S
SmoovC thank you sir you were right the lights worked after certain mph, thanks.
SmoovC
You are very welcome; glad to help. :)
CRV_33
Car: 2011 Infiniti M56x
Speaking of AFS lights, has anyone lowered their cars with an AFS-equipped car? Any issues with sensors and etc?
Ilya
I will be lowering soon'ish. I've never heard of this affecting anyone on the Y50 sub-forum, so can't imagine it would effect this car.
Ilya
Also, just an FYI, the driver side light works at 5mph but ONLY after you've managed to reach 16 or whatever first. I say this because when I pull into my long driveway which has a bend in it, mine still works. However, when I'm leaving the house, it does not.
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
CRV_33 wrote:Speaking of AFS lights, has anyone lowered their cars with an AFS-equipped car? Any issues with sensors and etc?
I'm on coils with the AFS headlights and don't have any issues.
CRV_33
IlyaKol wrote:I will be lowering soon'ish. I've never heard of this affecting anyone on the Y50 sub-forum, so can't imagine it would effect this car.
DoN_BLaZe34 wrote: I'm on coils with the AFS headlights and don't have any issues.
Alright thanks for the responses guys!
