Adapting new engine to work with active suspension car
mpoyner
I found a good engine with a warranty w/70K miles on it. My mechanic will be putting it in. He's a good mechanic, but something I'm sure he doesn't know is this: What needs to be done to it to make it work with my active suspension car?
Although I'm not positive, I'm assuming the engine didn't come from an active car.
Can I buy a service manual that would describe the process?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Basically its all the same, except you need to swap out your PS pump (also the active pump).... Other than that, youll need your ECU...
Is your car a TCS, california or federal...
If you give me the VIN numbers to both cars, I will run them and make sure your 100% compatible...
