Adapter plate woes
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
WYT R1CE
Why does nobody but mazworx sell an adapter plate? There is money to be made here. I for one would prefer not to have my bell houssing cut to use an adapter. Has anyone found anything yet? If I had a CAD layout a could get these flying off the assembly line.
argh.
DizzyKitty
Car: 2000 Maxima SE- in pieces in yard...
2014 Versa Note - Wife's vroom vroom machine
... are you asking for a CAD layout?
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
The problem is if you don't machine some of the bellhousing off you need a spacer to move the flywheel out to suit. I have a 1/4" adapter and needed a 8mm spacer to get it to even sort of work. The clutch release fork needs to traval nearlly all the way to the end of it's travel to get the clutch to release. I needed to extend the slave cylinder arm thing to even make it work.
If I have the gearbox off again, I will get some meat machined off it.
Boosted 70z
Car: 70 datsun 240z
http://www.xcessivemanufacturi...tep=4
Bart
Jus
WYT R1CE wrote:Why does nobody but mazworx sell an adapter plate? There is money to be made here. I for one would prefer not to have my bell houssing cut to use an adapter. Has anyone found anything yet? If I had a CAD layout a could get these flying off the assembly line.
argh.
extend the thrust bearing carrier as i did. Extend to the same thickness of the plate, if the plate is 15mm thick extend the thrust bearing carrier 15mm
tmorgan4
Car: 2000 Nissan Pathfinder
Woww...never heard of these guys! Thanks!
kingkilburn
Car: '93 240SX
Does any one have a picture of the engine and shifter placement using their kit? Their site doesn't have any.
Return to “VH45DE / VK45DE / VK56DE Forum”
