Bart wrote:The fat part of the extension is the same thickness of the adapter plate.I would make another but i have no material left in that diameter, plus postage from Sydney may be a little pricey, your best bet is to have an engineer make one for you.I can try and make up a diagram of it and post it here to save engineer time/cost.
The pilot bushing actually sits deeper in the crank than most people realize on Nissan, there is more than enough room to space it out further.CrazyTrance wrote:Wait, by doing this arent you putting the clutch disc way ou on the tip of the transmission shaft? Basically so close the teeth might not be going through the clutch entirely? Also not spacing the flywheel out would make it impossible to use a pilot bearing. Right? I'm just trying to picture how this is working.
