ad22vf problem
SA240SXCRUISER
Car: 93 240SX, 94 SENTRA, 2000 MAXIMA
does anyone know if you can use a torque member from another caliper to fit the ad22vf?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
not to my knowledge, not any sentra brake system anyways.
AWDB12wagon
Car: 1989 Nissan Sentra 4WD
nope
Chris859
I have installed the ad22vf calipers on a couple cars, and sold several sets as an upgrade "package" to customers at work. You need the 93 nx2000 (japan made/abs), or b13 SE-R w/ABS - Calipers, Caliper brackets, pads, and rotors. As far as I know that is the only direct combination you can do... Without fabrication anyways.
AWDB12wagon
Chris859 wrote:I have installed the ad22vf calipers on a couple cars, and sold several sets as an upgrade "package" to customers at work. You need the 93 nx2000 (japan made/abs), or b13 SE-R w/ABS - Calipers, Caliper brackets, pads, and rotors. As far as I know that is the only direct combination you can do... Without fabrication anyways.
91-3 NX2000 loaded calipers, and corresponding ABS or japanese made rotors...they will ask you "ABS or non" or JAPANSE made or US" Also...the rotor will be 257mm or just over 10 inches in diameter.
