since you listen to rock & rap, you should think about getting a vented/ported box.
That sub you're looking at should fit. The altima trunk I think can easily accommodate 8", 10" and 12" single and dual boxes. 15" boxes I'm not sure but I suppose it can fit if you have one custom done with dimensions you have for the installers.
You should also consider getting some sound deadener for the trunk area...put some underneath the rear deck where the 6x9's are, on the trunk lid, trunk floor and sides. I'm thinking that the doors might not need sound deadening, but it doesn't hurt to put some around where the speakers are to reduce vibration noises.
You should also look into doing the Big 3 electrical upgrade. You add on thicker gauge wiring to the factory points. The Big 3 is the cheaper way of reducing dimming of your lights whenever you upgrade the car audio. A better way to reduce dimming is to get a deep cycle battery for your starter battery such as a red top optima or kinetik or shuriken. It looks as though you already have a grounding kit, but adding more 4ga or thicker wire doesn't hurt!
Big 3 Upgrade explanation with pics:
http://forum.sounddomain.com/ubbthreads ... Post312025
