Actual Location of the Bluetooth Module
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Sgtnitro
Car: 2018 Versa SV Sedan
Greetings,
Has anyone ACTUALLY found the Bluetooth Module for a 2018 Versa SV Sedan? Everywhere I look it either says in the trunk or under the rear package shelf. Even crutchfield said it was in the right rear trunk. IT IS NOT. Has anyone had any luck hooking up an aftermarket stereo and retained their steering wheel controls? I have been told numerous times that the only way to retain the steering wheel controls is to add some jumpers to the bluetooth module connector..... I can't find the darn thing. Any and all help would be greatly appreciated, Thanks in advance,
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
On an '18 it's probably internal to the radio. I can look it up tomorrow, but almost nothing Nissan has had a separate BT for some time now.
VStar650CL
Technical Expert
Okay, I managed to get info from a different source and it depends what radio you have. On the base system (no color display) and navi the BT is internal to the radio. On the base audio with color display and the mid-grade, it does have one located behind the trunk trim on the righthand side.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome!
Oops. I had the wrong info. :ohno:
Sgtnitro
VStar650CL wrote:
Wed Jan 13, 2021 9:35 pm
Thank you.
VStar650CL
Technical Expert
You're most welcome!
Return to “Versa Technical Discussions”
