actsus question. manuals dont help...need experience advice. thanks
rasrx7
Car: 95 q45
91 President
94 Q45
03 Xterra
92 240sx hatch
93 240sx cionvertible
91 240 sx coupe
74 260z
73 240z
79 280zx
70 510 sedan
71 510 sedan
probably a noob question, but i have to ask. This is not my first g50, but my first with actsus. I was wondering about the coil springs in the actsus set up. I noticed that the actsus is pearched on top of the coil springs. Is the actsus just riding on top of the coils and all height adjustments are made from there. Bascially, the coils are just a base for the actsus. and shock/spring movements are from the bottom. The actsus technically doesnt have any shock in it? i hope htat makes some sense. just trying to learn more about the actsus that the manuals dont give. thanks for any help in advance....
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Yes, it is really a semiactive suspension as the springs support the car, but not enough to dynamically suspend it.
Read all of TexasOil's posts.
Q45tech
The active front spring is 108 pounds per inch vs the non active springs 146 pounds of stiffness........................so hydralics provide ~ 25% of static lift and 100% of shock dampening.
Individual wheel shock values are the result of the high pressure nitrogen charge in each accumulator.........................when this gas charge leaks out the wheel or all wheels become stiff, jerky, and rigid.
