First an intermittent actsus light may be somethig as simple as low oil level or a height sensor. First run the on board diagnostics---1) with the car shut down, transmission in P, turn the key to 'on' do not crank. 2) within 10 sec of key ON, turn the N/H switch fron N to H and back 10 times, stopping in N
3) the self diagnostics should start. In a few moments it will begin flashing a series of pulses, repeating till you turn the key off.
first series is 10's, second series is 1's 5 followed by 5 is '55', which means electricals are aok.
Let me know what you get.
Second thing is to determin how much suspension travel is left (as the nitrogen dissipates, you get less and les suspension travel.
With car running, bounce real hard on each corner (or get someone 200# to do it for you. The goal is to see how much smooth and damped travel is left. Fresh is about 5"
Exchange recharged accumulators are an easy swapout for the 4 struts, and at $200 each, are lots cheaper than converting (have to change springs, mounts, etc, etc.
The strut (shock) portion of the 'actuator' as they call them is extremely robust and should last practically forever--which conventional struts will not (50K miles max, and another $1200 job). With fresh strut accumulators it will ride as good or better than any conventional suspension Q45. If you go with aftermarket struts, they ride harsh and wear out quick I am told.
Like any high precision hydraulic system, the life is determined by fluid cleanliness. There are built in fine filters in the system, but the fluid should be replaced every 60-100K miles to keep it as new
send me an email off line (
[email protected]) and I will send you a few articles explaining the system and how to keep it really active. Folks who do not understand the system can easily get scared by horror stories of what CAN happen, just like complete engine replacement stories - seldom, but $10K when they happen. IF the unthinkable failure should ever happen, AND I did not have good used parts to swap out, one could always then convert to standard suspension and live with the inferior ride and handling.
