goody94q45 wrote:
I don't own an active but isn't there a hi/low (or equivalent) switch somewhere on the dash. It doesn't disable the active but lowers the ride height. From reading your other posts it sounds like you've inherited some suspension problems. I don't recall, but have you done the self-diagnosis from the FSM? Good luck.
Correct.There is a switch to change the ride height from low to high, but not one to turn it off?!
Not exactly a system that you can turn on and off at your leisure.... and you wouldn't want to anyway...
